GPIO crashing when tuning MS2
zen
gpio crashing when altering ms2 settings..new tuner studio?
Post by zen »
ruby mary + accel 4 OPEN LOOP..msq
(109.16 KiB) Downloaded 1187 times
hi
when tuning the ms2 msq, ie lets say altering the idle steps for tick over, once hit burn gpio crashes..ie refuses to change gear, wont even go into reverse..
also, it seems to take a age for changes to ms2 to be implemented..ie changing iac steps from 50 to 40 , 30 secs later it does so..
also..idle up and advance settings in gpio do not work..yes constraints are meet, ie tps 0, in first, 0 mph..
now as only driven from home to test station, am not sure if was like this before yesterday..yesterday i updated my tuner studio..coincidence???
hopefully msq's are here....gearbox is gpio.
ruby mary + accel 4 OPEN LOOP GEARBOX MSQ..msq
(109.16 KiB) Downloaded 1103 times
zen
Re: gpio crashing when altering ms2 settings..new tuner stud
Post by zen »
forgot.....thanks..any ideas??
Matt Cramer
Post by Matt Cramer »
Can you post what version number of TunerStudio and what MS2 fimrware version you're using?
zen
Post by zen »
hi
ts is v2.6.04
and ms2 is i have no idea as not near car..i will post tomoz , but about 6 months old??maybe less
zen
Post by zen »
hi..
gpio firmware 4.139..with ms2 extra330n2
now if i am tuning the ms2 tables..say fuel table 1 on the go..ie driving it will crash the GPIO..
by crash i mean specifically it will NOT see the manual gearchange inputs from the gearshift switches..IT will change gear in auto forward gaers, BUT will not go into reverse as it does not see a change fron the shifter..
if i cut power and restart all is fine..
tuner studio is V2.6.04
any ideas??thanks
Re: GPIO crashing when tuning MS2
Simon,
This error could be from a number of things; from ms2 or TS, or the CAN physical connection. But it may also be a gear lever error. So the first thing I would try is disabling the lever error function. This is under "Error Behavior -> Lever Error Behavior"; set it to: "Ignore Lever Errors". There is more here: http://www.msgpio.com/manuals/mshift/V41tune.html#ge
zen
Post by zen »
update..(this is before vss issue)
rewired canbus and turned off gear lever errors as you suggested..seems ok now thanks..
SO anyone reading this in the future..re do your can bus wiring..its been perfect since..
zen
Post by zen »
this was related to iffy canbus wiring...
