GPIO crashing when tuning MS2
gpio crashing when altering ms2 settings..new tuner studio?
when tuning the ms2 msq, ie lets say altering the idle steps for tick over, once hit burn gpio crashes..ie refuses to change gear, wont even go into reverse..
also, it seems to take a age for changes to ms2 to be implemented..ie changing iac steps from 50 to 40 , 30 secs later it does so..
also..idle up and advance settings in gpio do not work..yes constraints are meet, ie tps 0, in first, 0 mph..
now as only driven from home to test station, am not sure if was like this before yesterday..yesterday i updated my tuner studio..coincidence???
hopefully msq's are here....gearbox is gpio.
- ruby mary + accel 4 OPEN LOOP GEARBOX MSQ..msq
- (109.16 KiB) Downloaded 1094 times
Re: gpio crashing when altering ms2 settings..new tuner stud
Matt Cramer
ts is v2.6.04
and ms2 is i have no idea as not near car..i will post tomoz , but about 6 months old??maybe less
gpio firmware 4.139..with ms2 extra330n2
now if i am tuning the ms2 tables..say fuel table 1 on the go..ie driving it will crash the GPIO..
by crash i mean specifically it will NOT see the manual gearchange inputs from the gearshift switches..IT will change gear in auto forward gaers, BUT will not go into reverse as it does not see a change fron the shifter..
if i cut power and restart all is fine..
tuner studio is V2.6.04
any ideas??thanks
Re: GPIO crashing when tuning MS2
This error could be from a number of things; from ms2 or TS, or the CAN physical connection. But it may also be a gear lever error. So the first thing I would try is disabling the lever error function. This is under "Error Behavior -> Lever Error Behavior"; set it to: "Ignore Lever Errors". There is more here: http://www.msgpio.com/manuals/mshift/V41tune.html#ge
rewired canbus and turned off gear lever errors as you suggested..seems ok now thanks..
SO anyone reading this in the future..re do your can bus wiring..its been perfect since..
