Control ZF 5hp19 TipTronic
formigoni
Post by formigoni »
Hello Guys,
My name is Vinicius Formigoni, I'm from Brazil.
Thank you for being part of this Forum.
Sorry for my English.. :D
Would you like some help if possible ...
This board GPIO can control a gearbox ZF 5HP19?
Thank you very much.
Formigoni
Re: Control ZF 5hp19
Formigoni,
No need to be sorry for your English, it is perfect (and much better than my Portuguese!).
I don't know if the board can control the trans you mention. Someone may have done the homework to find out, and hopefully they will reply with a definitive answer.
If not, you can check yourself with this guide to get a list of what you will need to know: http://www.msgpio.com/manuals/mshift/newtrans.html If you aren't sure abut anything, post here (ideally listing the answers to the questions you can find information for).
It might help to generate some responses if you listed some of the vehicles this trans came in as well. At very least, it would help others to look up specs on your trans.
formigoni
Post by formigoni »
Thanks Lance,
I will check the manual guide...
This GearBox ZF 5hp19 went models VAG (VW, Audi, Porsche)...
Look.
http://www.europeantransmissions.com/Bu ... /00-39.pdf
Thank you very much
Formigoni
Formigoni,
That's funny, because we have that exact transmission in one of our test cars (a 1998 VW Passat 1.8T). This car is currently being used for testing other (unreleased and unannounced) projects at the moment, but it is likely it will get MShift at some point. I will attach some of the info I have.
ZF_01V_transmission.pdf
(1011.47 KiB) Downloaded 806 times
The solenoid logic is shown around page 15.
formigoni
Post by formigoni »
Ok Lance,
That's good to know that are already testing...
This manual you posted I also already have here in my files.
You have the wiring diagram of a GPIO for this gearbox?
Any picture or PDF file?
Formigoni
Formigoni,
I have done no work at all on this transmission with respect to the MShift/GPIO. I am just gathering documents so that I can do it eventually. I will get to implementing MShift on it, but it will very likely be quite a while before I have time for this (because other projects have a higher priority at the moment).
If you (or anyone else) wants to gather and organize the required information (http://www.msgpio.com/manuals/mshift/newtrans.html) that will likely speed things up, like deciding on the required wiring, parameter setup, and code changes, etc..
formigoni
Post by formigoni »
I will study for a long period this manual ... :lol:
Formigoni
16V-Sauger
Re: Control ZF 5hp19 TipTronic
Post by 16V-Sauger »
Hello guys,
any progress on this topic?
kind regards
formigoni
Post by formigoni »
Hello people,
Unable to make progress on this project, I am in search of parts for after starting work.
The gearbox I bought came missing many parts.
Thank you,
Formigoni
16V-Sauger,
Unfortunately, our test car with this trans blew its engine, so we have done no work on this recently.
