CAN TPS values erratic or scaled down
Now I can't drive the Jeep to test it with the new firmware since the CAN TPS once in the trans controller is unusable, I have made a datalog so you can compare engine TPS and trans TPS, but there is no such thing and load follows MAP, so I have made a video, you can see that while I press the go pedal it does not follow and become erratic past 30ish%then it will sort of follow while backing down under 30%, note that the load indicator stays in KPA but the Shift table operate on the CAN TPS like it should.
http://www.youtube.com/watch?v=6hpggVTa ... e=youtu.be
Thanks for help
- 2013-06-26_12.53.01.msl
- (417.55 KiB) Downloaded 972 times
- Trans_CurrentTune.msq
- (45.06 KiB) Downloaded 1253 times
Re: CAN TPS values erratic or scaled down
Oops, I have buggered up the TPS, and this may be related to some other issues I am hunting down related to the MAP, short term load, and other load values like TPS. I hope to have a fix out this evening or tomorrow morning.
In the meantime, you should probably revert to 2.204 code: http://www.msgpio.com/manuals/mshift/fi ... 04.abs.s19
I have put new 4.126 code here: http://www.msgpio.com/manuals/mshift/V41code.html
This fixes the TPS issue, at least on my bench.
