4L80E Megashift and MS2
flak monkey
I've spent a while looking through the manuals for both the MS2 and the Megashift and I seem to be missing something somewhere...
I don't currently have any CAN set up on the MS2 - nor have I ever played with it on previous installations. I'm using all of the SPR outputs on the MS2 DB37 connector for various things, so I'll have to bring them out on another connector somewhere. I assume it is as simple as running some jumper cables from JS6 and JS8 to another connector and hooking them into the GPIO ampseal connector? Is there any code modifications required other than adding the Megashift as a CAN device in the MS2 project?
To be honest the CAN pages on the MSExtra site are just plain confusing to someone who knows nothing about it.
Re: 4L80E Megashift and MS2
Did you see this: http://www.msgpio.com/manuals/mshift/cpt.html ? It details all the required connections, and there is a video on setting up TS too (http://www.msgpio.com/manuals/mshift/CAN_setup.wmv).
You will also want to check this link: http://www.msgpio.com/manuals/mshift/V5tune.html#oa for user settings specific to MS2extra (in a box labelled "MShift™, CANbus, and MS/Extra Code").
flak monkey
