100% Line pressure
Posted: Wed May 07, 2014 4:00 pm
by 1991blazer
Ok now that I have everything else working great, there is just one last problem. The system at times will stick at 100% line pressure in any forward gear, then at times it is perfect. Makes for interesting shifts into 2nd behind this diesel. When I pull up the table while driving the dot that shows the current bin is working as it should but the gauge on the TS shows 100%. Attached is a log and MSQ with it stuck in 100%.
Aaron
Re: 100% Line pressure
Posted: Wed May 07, 2014 4:02 pm
by 1991blazer
Forgot running code 4.139
Posted: Wed May 07, 2014 4:48 pm
1991blazer,
I will have a look shortly. Off the top of my head, one thing that can do this is having the jake brake input activated. But it could be something else and I will look at your MSQ and log.
Posted: Wed May 07, 2014 5:29 pm
1991blazer,
There was a problem in the Jake brake (engine compression brake) code in setting the Jake brake status variable, and this might have been the cause of your issue (or maybe not). If you could give the attached 4.141e test code a try, it would help sort things out. The attached INI has added a bit for the Jake brake status, so that will show its status in a datalog.
Monitor_4141e.abs.s19
(72.76 KiB) Downloaded 860 times
GPIO_MShift_4141.ini
(218.44 KiB) Downloaded 865 times
If this code doesn't help, a fresh datalog should point to the issue. If this code does fix the problem, it will become a part of all future releases, of course.
