100% Line pressure
1991blazer
100% Line pressure
Aaron
- 2014-05-07_16.44.23.msl
- (307.8 KiB) Downloaded 762 times
- 2014-04-29_19.18.10.msq
- (45.3 KiB) Downloaded 933 times
1991blazer
Re: 100% Line pressure
I will have a look shortly. Off the top of my head, one thing that can do this is having the jake brake input activated. But it could be something else and I will look at your MSQ and log.
There was a problem in the Jake brake (engine compression brake) code in setting the Jake brake status variable, and this might have been the cause of your issue (or maybe not). If you could give the attached 4.141e test code a try, it would help sort things out. The attached INI has added a bit for the Jake brake status, so that will show its status in a datalog.
If this code doesn't help, a fresh datalog should point to the issue. If this code does fix the problem, it will become a part of all future releases, of course.
