and another thing, canbus connection?
tmoble
Post by tmoble »
I'm going to be using the canbus to feed engine info to the the mshift. The only canbus thing I saw on the board was termination resistor. I found something somewhere that said canbus would be on pins 13 and 16 of the 35 pin connector. I put those wires in the connector but I'm wondering what they connect to on the board? I don't recall building any circuit for canbus? Is it magic or did I miss something? I looked again at the list of connections in the Jumper chart, don't see anything about it.
Re: and another thing, canbus connection?
Except for the termination resistor, the CANbus circuit is already installed as SMD components during the manufacture of the GPIO board. The circuits are all described here: http://www.msgpio.com/manuals/gpiohw.htm
tmoble
Post by tmoble »
Thank you Mr Fife. Say, did you ever get another bullet?
