EGT Circuit while using megashift
12lbchevelle
Probably a stupid question..
Re: EGT Circuit while using megashift
Yes, you certainly can install an EGT circuit. If you have spare ADC input circuits left to log the output, you can read the temp from the voltage by using some math in the TunerStudio INI file. You might have to jumper the EGTx circuit to another pin on the 50x2 header, depending on which circuit you use.
The default assignments for the free ADC's in a typical 4L80E build are:
PAD04: EGT2, Ampseal pin 27,
PAD05: EGT1, Ampseal pin 24,
PAD06: GPI5, Ampseal pin 5,
so EGT1 or EGT2 make the most sense. If you do this, I can easily add code and INI mods that will make it work for you - if you are willing to test it.
I suspect people interesting in logging EGT may also be logging line pressure, so the non-CAN MAP circuit (EGT1) might be the one to use for the most general application (since not using CAN already means you aren't getting as much data to log). I could potentially set it up to work on either or both, I suppose.
