ABS/TCS retrofit
ABS/TCS retrofit
anyhoo. i think the research was based around the bosch 5.3 unit or some other similar non-integrated hardware. anyone remember this, or care to offer suggestions on what a retrofit might require?
Re: ABS/TCS retrofit
That info is currently being re-worked. Here's a zip of the page (attached). Which non-integrated ABS unit we will initially support hasn't been 'set in stone' just yet.
- abs_hydraulics.zip
- Early draft of ABS page
- (24.1 KiB) Downloaded 3927 times
i'll be fishing around for info on this, if i see any nuggets of info i'll post it here.
i haven't seen any examples of a WSS tone ring (toothed wheel) getting retro-fit to hub assemblies that did not originally have one, but i'm hearing it's been done. i'd really like to see an example before i try to recreate the wheel (pun intended).
http://www.desert-craft.com/featured.html
They install on CV joints. I dont know what you would do about the front wheels, no ideas have come to mind yet.
phongshader
Olds 215 v8 in a '59 Alfa Romeo Spider 2000
MS2/Extra 3.1, V3, TS 1, LC-1
Duratec 2.3, GSXR itb, Locost
Yes, there is progress, but nothing to announce. We are still a ways away from distributing useable code.
phongshader
phongshader
The code is written to be general at this point (based on the physics of vehicle acceleration and traction, etc.). The target hardware has been left 'unspecified'. The idea is that the code should work with most hardware.
Like the trans code, there will likely have to be some code additions and modifications to suit everyone's hardware and needs, but we will make every effort to do this. Also like the trans code, the more people ask for modifications, and the more information they can supply, the more easily those modifications can be made.
Unfortunately, with the trans code, DBW code, and stability code all on the table (along with various other projects) progress is currently slower than we would like.
I was told to check out this link by Matt over at DIY Auto Tune, I'm trying to make the ABS on a project car work and was thinking that rather than to try and make the OEM Buick Riviera computer work with my cobbled together system, that a programmable unit would be much more suitable.
How is the progress with the ABS coming?
Cris
