hard downshifts when stopping
Posted: Sat Aug 02, 2014 4:42 pm
by shaodome
So this might be a stupid question, but that has YET to stop me....
When slowing down the car hits some pretty hard downshifts. What is the best way to prevent that type of behavior? Load hysteresis?
Re: hard downshifts when stopping
Posted: Sun Aug 03, 2014 5:41 am
shaodome,
Hard shifts are the result of high line pressures or downshifting too early. When you are slowing down, the load should be very low (near the bottom of both the line pressure and shift table). So if this was mine, I would experiment with:
- lowering the line pressure at the lowest loads and particularly at the speeds where the shifts occur,
- lowering the shift speeds at the lowest loads by moving all the entries in the bottom row (or two) of the shift table a cell to the left (or maybe two or more to the left, depending on your configuration).
That should help. If it does, then you can experiment to find the best settings for the way you like it to drive. You *may* have to change the load bins to get them so that the cells in the bottom row are in effect in the load range where you are downshifting.
This won't affect the power on upshifts because they rely of the higher load entries nearer the top of the tables.
Posted: Sat Aug 09, 2014 5:17 am
by shaodome
Used both of your suggestions. All good now. Thanks for the fast responses as always Lance!
