PCneutral = scalar, U08, 120, "%", -1.00000, -100.00, 40, 100, 0 ; pressure in neutral
pc_table = array, U08, 273, [16x9], "%", -1.00000, -100.00, 40, 100, 0 ; The PWM% for PC solenoid by load and mph
etc.
You change the value of 40 to something lower like zero (which would be 100% PWM).
The lower limit of 40% prevents people from burning up their transmissions internally (both the friction elements from slippage and the solenoids from the higher current). But if you know what you are doing, you can probably go lower.
