Re: Toyota A750f Transmission control
Posted: Tue Jan 03, 2017 9:04 am
If I recall correctly (I haven't looked at the code for a while), the 40% limit is entirely in the INI. To change the limit, you need to find all the places in the INI it is specified and change it. This would be things like:
etc.
You change the value of 40 to something lower like zero (which would be 100% PWM).
The lower limit of 40% prevents people from burning up their transmissions internally (both the friction elements from slippage and the solenoids from the higher current). But if you know what you are doing, you can probably go lower.
PCneutral = scalar, U08, 120, "%", -1.00000, -100.00, 40, 100, 0 ; pressure in neutralCode: Select all
pc_table = array, U08, 273, [16x9], "%", -1.00000, -100.00, 40, 100, 0 ; The PWM% for PC solenoid by load and mph etc.
