Page 2 of 2
Re: minimum pressure of 40%
Posted: Tue Mar 25, 2014 5:58 pm
by mill3833
4.138 did the trick. I can now command 0% PC in Park if I want.
Thanks again for excellent support.
Posted: Tue Mar 25, 2014 6:33 pm
I'm glad that worked. The code has become quite complex, so finding these things often takes a little longer than I like. I will update the 5.xxx code with the same fix shortly <edit>it turns out that section of the 5.xxx code had already been re-written (for use as spare port 3) so it ought to be okay 'as is'.</edit>. Both will be released in the code updates thread.
