CAN communication problem
flak monkey
When the GPIO is hooked up via CAN I have a number of problems, all intermittent. After a couple of minutes I get various settings errors flash up and then all of the gauges in TS move to junk figures. Disconnecting the CAN I can get good comms to the MS2 only, and similarly to the GPIO via serial. It's only when CAN is hooked up I have a problem.
While it is working OK I seem to have communications between the MS2 and GPIO.
Tunerstudio v2.6.14
MSExtra 3.2.4
GPIO 4.14.6
I've got the CAN outputs from the MS2 out on SPR1 and SPR2 and linked directly to the CAN inputs of the GPIO via a twisted pair.
I've set the GPIO in the Tunerstudio project properties as device 1, enabled CAN comms in the configuration settings and selected the INI file for the GPIO per the instructions in the GPIO manuals. I haven't fiddled with any other settings, everything is as default.
I assume that there's no need to change the CAN parameters in the 'Advanced' settings menu for the MS2?
I've attached an MSQ, but I'm not sure it'll help much in this case?
Any ideas of where to start would be great.... I don't know much about CAN at all to be honest.
ETA: its acting like this without the engine running at all.
- 2015-04-22_18.17.25.msq
- (85.38 KiB) Downloaded 1249 times
Re: CAN communication problem
Do you have trouble with the CANbus communication between the GPIO and engine controller (i.e. getting the engine variables over the CANbus to MShift), or does the problem only occur when using the CANbus pass-through (connecting to the MShift/GPIO for logging and editing parameters when the serial is attached to the engine controller)?
Communication problems are often the result of mis-matched INIs. If this was mine, I would start by create a new project from scratch in TunerStudio using freshly downloaded INIs. Don't use the INI suggested by TS, instead navigate to the INI you downloaded.
However, before doing that, you might want to consider updating the MShift code to the latest release 5.100 (http://www.msgpio.com/manuals/mshift/V5code.html) as 4.146 is now obsolete, and any fixes would be applied to 5.10x. Also, 5.100 has a number of changes to the interrupt infrastructure that might solve your communications issues.
A debug comms log in TS would tell us why the comms are failing, so that would be a useful thing to grab and post.
I don't know about the CANbus settings in msextra, you'll have to ask about the that on the msextra forums unless someone here is using ms2/extra and can comment.
flak monkey
I'll revert to an old version of my MS2 MSQ. Load up a new project with the latest release codes for both the MS2 and Megashift and then start again.
I am a little worried that I might have screwed something up by forgetting to pull the fuses for the solenoid power when using the bootloader. But I'll worry about that later if I can fix the communication issues.
To be honest I initially struggled to find the latest version of the code without going back to the main page, even then I managed to find a link to what looks to be an earlier version - though this morning I can't find where I downloaded 4.146 from now. Both the links on the 4L80E build page for the code here: http://www.msgpio.com/manuals/mshift/4L80E/4L80.html on step 12 are broken. Links to this page which is dead: http://www.msgpio.com/manuals/mshift/4L ... sions.html
On the subject of broken links, both links in the build guide (same main page as above) for the troubleshooting of VSS/VR sensor issues on VR1/VR3 circuits is also broken. They link to this page: http://www.msgpio.com/manuals/mshift/4L80E/vss.html which is dead. Should be this one: http://www.msgpio.com/manuals/mshift/vss.html
I will fix the broken links. The latest code is here: http://www.msgpio.com/manuals/mshift/V5code.html
flak monkey
The only thing to be aware of is that when you connect back to the MS2 you will need to be sure to have updated the megashift ini file under CAN communications in TS.
A good thing that I have found is that when TS performs its difference report it does megashift and megasquirt seperatly.
flak monkey
I finish work in a hour, then I can try it again tonight with the latest versions of the code for both MS2 and MShift and see if that resolves the problem. I'll run a comms log tonight as well and see if I can see what's going on if it doesn't work.
If it's still acting up I'll take a video of the screens and settings which might help as well.
flak monkey
That's progress! Thanks for letting us know. Hopefully it will work fine from now on, but be sure to let us know if there are further issues.
flak monkey
Haven't driven it yet, car is up on stands, but had it running for a while over the weekend and in gear too. So happy it's functional. Can move on to the next job now
