More VSS Issue
More VSS Issue
This sensor is supposed to have 4 teeth and that is what I set up when I use it in the MS3 firmware. In this case it is only accurate if I put 1 for the number of teeth. The tire size, gear ratio, etc are all correct for the application.
Up until around 30mph everything is perfect, if I push the throttle harder at that RPM it'll jump to 100mph or there about, thus really messing with the shift solenoids. I started to think there might be something wrong with this particular sensor, so I switched over to the OEM cluster signal which comes from the ABS computer. The dash cluster is as steady as a rock. When I hook the GPIO to use that as the VSS I see the SAME behavior on the speeds above 30ish.
If I increase the number of pulses in the GPIO VSS settings the calculated speed goes down until I get to the same 30ish (real life) mph mark. Then it goes nuts.
In my case, I bypassed the entire GPIO VR sensor input an just jumpered the bottom of R42 to R59 to bring the input right to the processor pin. I've done this on MS3 with the JS4 input and never had an issue. Thoughts?
