Tire Diameter >70
skihnia
Tire Diameter >70
Post by skihnia »
Hi,
I have a MegaShift on a offroader.
I tied to set the VSS settings and now have few problems.
I'm unable to set the "Tire Diameter(cm)" over 70. That is quite little for an offroad vehicle.
Also I had the "4WD Speedo correction" at 1 but when I touched it I'm unable to set it under 1.960.
MS versio: 4.127
Re: Tire Diameter >70
skihnia,
Whoops! That's a typo in the INI (the metric (180cm) and imperial (70") limits were swapped not too long ago when we went from NOT_METRIC to SI_LENGTHS settings).
A fixed INI is here: http://www.msgpio.com/manuals/mshift/fi ... t_4127.ini
The FWD setting was carried over from when the switch was used only for 4/2wd switching. It is also fixed in this INI, so now it can go from 0.1 to 6.0.
