Megashift Stimulator?
I was just wondering if the status of the MShift/GPIO (?) stimulator had changed to a "yes" while I was away waiting for my 41te tester to get back to the trans. It seems he's almost back with us, so I'm trying to get back up to speed. If I could whip up a stimulator for testing my setup and getting familiar with the interface within MTune, it would be great.
Thanks!
Thad
Re: Megashift Stimulator?
I have received very little interest in the trans stim over the last few months, so nothing has been done. If enough interest is shown, I will get some made up.
RacerStev is going to start working on figuring out the wiring and needed circuits for the 41te (and making up some diagrams like dch did for the 4L80e), so we should be getting back in the swing of things for that Beta testing. Unfortunate delay, but I still think there is going to be a lot of interest in this setup when we get one running well. Steve is excited about some of the features of the code with the solenoid dithering, refresh cycles, etc.
Thanks!
Thad
The plan for future releases of the trans stim is to:
- add the ability to implement a 'resistor' style shift lever (such as that seen on Fords) in addition to the 'digital' 3-switch style used on GM (since we already have a 2-pole 6-position switch in the BOM this is almost trivial),
- include more LED outputs to show the use of spare ports and things like that,
- possibly include a simple VSS signal generator (the crank wheel pulser can be used for this too, but a 'one-board' solution with a pot speed control is probably best).
The user would have to use the default 4L60E input pattern to get the gears right, but at least they could be sure that the input hardware worked once built (having a multiple jumper scheme to use custom input patterns might work too, but adds cost and complexity - two things that aren't wanted in a stim, I think).
Using the default input pattern, it's easy to see if the output pattern matches what you expect (based on the output patterns the users specifies). So it is generally pretty handy - I have used mine LOTS while developing the hardware/software.
I'd be interested in one for sure, but without one it looks like I can probably get by to some extent. I just started reviewing my old posts, and I think you had indicated that I could probably manage with my old-school stim, my JimStim, and my MS2. I am running MS3 currently, but I can pop the MS2 back in for testing if necessary.
Next I'll be continuing to re-trace my old posts to refresh my recollections of all of this stuff from before.
Thad
