CAN Settings with MS3 (PC control CAN)
Posted: Mon Feb 11, 2013 12:29 pm
by tobmag
Hi Lance.
So I have now the my GPIO connected over CAN to my MS3 with the MS3X card, everything seems to work with the CAN connection.
One thing I need to get confirmed that it is correct,(I have no stim to the MS3 so testing is not that scientifically)
PC stays on 100% independatntly of the load, tested both TPS and MAP (hooked up tps to the trans stim) Load does change in TS so CAN is working
PC% does blip to 70% while shifting as it should.
Is PC sitting on 100% due to the missing engine rpm input?
While I had the GPIO as "stand alone" PC was following load as it should.
Re: PC control CAN
Posted: Mon Feb 11, 2013 12:58 pm
Either missing RPM or missing load can do this. The PC is set to 100% if the engine isn't running because this reduces the current draw (PWM=100% is minimum current draw because the PC solenoid is a 'bleed' valve) and eliminates some PWM noise. Of course, if the engine isn't running, the trans doesn't need the line pressure reduced (or to do much of anything else, of course).
Re: PC control CAN
Posted: Mon Feb 11, 2013 1:03 pm
by tobmag
Hi Lance.
Thanks for the clarification. I knew there was a logical explanation for this.....
Re: PC control CAN
Posted: Wed Feb 13, 2013 10:20 am
by tobmag
Hi Lance.
Here is my MSQ from the mS3 set up. I'm using the latest MS3 code avalible; 1.2.0
You need to do the following changes in the CAN configuration under "Tools" and change ;
MS-II in2ram block to 7
MS-II variable offset to 630
There is a question mark for the above since these values are locked in the .ini
CAN config.JPG (46.74 KiB) Viewed 14594 times
According to MS3 manual;
On MS3 Advanced2->Speed/Gear sensors set gear to CAN and
CAN ID 1, Table 7, Offset 12
VSS - unknown
Should be On MS3 > Advanced Engine >Speed and gear sensors
Make the settings as on attached pic.
speed gear sensor.JPG (93.16 KiB) Viewed 14594 times
Then on MS3 go to CAN/Testing > CAN VSS, gear, EGO
Re: CAN Settings with MS3 (PC control CAN)
Posted: Wed Feb 13, 2013 10:23 am
by tobmag
And here is the MSQ I was using.
//Tobmag
Posted: Thu Feb 14, 2013 9:21 am
Thanks for posting this, it is sure to be helpful to many other users! I will add the info to the manual as well.
