Page 1 of 8
MShift and Toyota A34 Series Info?
Posted: Tue Mar 20, 2012 1:22 pm
by phoenix3d
Hey There everybody....
Anyone know of any available info for building GPIO and available MSQ or settings for Toyota A34 series Trany's? (No the Gearboxes........;-)
Any help will be appreciated...
I have got to build up 4 GPIO's for these Boxes... for starters....
HELP PLEASE!!!!!!
Cheers
Gordon.
Re: MShift and Toyota A34 Series Info?
Posted: Tue Mar 20, 2012 4:36 pm
by gross polluter
I'm running a MKIV Supra TT trans on MShift, A341LE. Circuit construction is the same as 4L60E, except you need to add two P channel FETs for the shift solenoids since they're going-high switching instead of going low.
EDIT: With the newer code just released, the SP1 output can be used for accumulator pressure control.
Posted: Tue Mar 20, 2012 10:11 pm
by phoenix3d
Awesome... Thanks for the Speedy reply...
Could you forward a bit more info (Specifics) I aint so clued up... Hahaha...
Thanks again for your help.
Cheers
Gordon.
Posted: Tue Mar 20, 2012 10:36 pm
by gross polluter
I'll work on making a post on this forum in the next few days since there seems to be a large audience of A series transmission owners on this forum.
Posted: Wed Mar 21, 2012 11:36 pm
by phoenix3d
Woooo Hoooo....!!!!!!
Thanks a Stack.... Can't wait!!!
Wanna Start playing......
Cheers!
Posted: Thu Mar 29, 2012 1:25 am
by phoenix3d
Hi There... Gross Polluter...
Any headway with the posting for the A34 series stuff?
Waiting with anxiety!!!!!
Cheers!!
Posted: Sun Apr 15, 2012 7:57 pm
by mikeymkll7mgte
Can someone explain how to do this? This is my last step before I can get the car driving. A diagram would even be better. Any recommendations on what FET to use? Thanks!
Posted: Thu Apr 26, 2012 5:11 am
by Jim Blackwood
Probably didn't get a reply because this is more of a general electronics question. Without getting into the specifics, which would require me to research the details of the exact circuit in question, you are dealing with PNP and NPN transistors. So using basically the same signal in on the gate, one uses ground as a source and the other uses B+, thereby driving the load to either ground or battery potential. Often the simple solution is to replace the driver with one of identical specs but opposite polarity, paying attention to the requirements of the gate. That's the simple answer, but I'm sure there is an established and tested method of dealing with this specific circuit. You might find the answer in the general MS forums, GPIO perhaps.
Posted: Thu Apr 26, 2012 6:55 am
mikeymkll7mgte, Jim;
Googling "gross polluter gpio pnp" turns up this thread: http://forums.turbobricks.com/showpost. ... tcount=250
Posted: Thu Apr 26, 2012 7:01 am
by mikeymkll7mgte
I did find that thread. I also had to install a 1k resistor inline between the output of the NPN and the input of the PNP. Im having another issue with the transmission now though... When it tries to shift into 3rd (i think) under load, it acts like its trying to go into 2 gears at once and slows the car and lugs the motor down. It shifts fine with no ecu connected and going through the gears manually (with no ecu, you only have 1st, 3rd, and 4th) Im doing further testing tonight...
