MShift and Toyota A34 Series Info?
Re: MShift and Toyota A34 Series Info?
Forgot one other thing- Im using MS3X and tied to MShift over CAN. It wont burn shift tables over CAN, and sometimes some of the settings dont "stick". I have to be plugged in directly to MShift to do any changes to it. Is this normal with MS3X and MShift over CAN?
I am glad it is working for you. You should be able to use the full time lock up settings to lock the converter in 3rd gear and up. See: http://www.msgpio.com/manuals/mshift/V22tune.html#nt Just set the rpms low, and the gear to 3rd.
I always test the CAN flash burn before release, and just re-checked it with 2.202 MShift code and it works fine. But that's with MS-II running 2.905 code.
It could be that not enough time is left after a burn before shutting down. The whole process can take several seconds over CAN (because of all the other stuff happening on the CAN network), so you have to be quite slow and methodical. However, it may be that MS3 has a bug in the CAN code that is causing packets to be dropped, and you can ask about this on the MS3 forums (I don't have an MS3 to test the CAN comms). You can also try asking about this on our TunerStudio forum ( viewforum.php?f=12 ) to see if Phil thinks there is anything in TS that might cause this behavior.
I am guilty of occasionally turning my controller off within a few seconds of burning and that will result in corrupted firmware. I'll usually count to 10 after the burned indicator has turned off to ensure I don't corrupt my settings.
