non-CAN TPS issue
warrjon
non-CAN TPS issue
Post by warrjon »
I am trying to get the TCU setup as standalone with TPS as load (until I get the MS2 installed)
I have set the TCU up on the bench with a pot connected to my lab supply (5volts) as a temporary TPS and verified I am getting TPS voltage at EGT1-AD5 jumper.
My issue is when I enter calibrate TPS I get this message
"Unable to register TP ADC OutputChannel TPSADC"
Click OK and TunerStudio brings up the Calibrate TPS dialog.
When I try and calibrate both closed and full throttle ADC count is ZERO.
What am doing wrong??
warrjon
Re: non-CAN TPS issue
Post by warrjon »
I should have included these files
mainController.ini
(316.19 KiB) Downloaded 898 times
(62.15 KiB) Downloaded 907 times
