Maximum shift line pressure
Re: Maximum shift line pressure
See this: http://www.msgpio.com/manuals/mshift/V5tune.html#gl This is limited to 90% by the INI. You can change that limit by editing the INI lines:
; maxUPpressure1 = scalar, U08, 634, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 1st
maxUPpressure2 = scalar, U08, 635, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 2nd
maxUPpressure3 = scalar, U08, 636, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 3rd
maxUPpressure4 = scalar, U08, 637, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 4th
maxUPpressure5 = scalar, U08, 638, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 5th
maxUPpressure6 = scalar, U08, 639, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 6th
maxUPpressure7 = scalar, U08, 640, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 7th
maxUPpressure8 = scalar, U08, 641, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while upshifting to 8th
maxDWNpressure1 = scalar, U08, 642, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 1st
maxDWNpressure2 = scalar, U08, 643, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 2nd
maxDWNpressure3 = scalar, U08, 644, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 3rd
maxDWNpressure4 = scalar, U08, 645, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 4th
maxDWNpressure5 = scalar, U08, 646, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 5th
maxDWNpressure6 = scalar, U08, 647, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 6th
maxDWNpressure7 = scalar, U08, 648, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 7th
; maxDWNpressure8 = scalar, U08, 649, "%", -1.00000, -100.00, 40, 90, 0 ; Max pressure while downshifting to 8th
changing the 90 values to 100, like this:
maxUPpressure1 = scalar, U08, 634, "%", -1.00000, -100.00, 40, 100, 0 ; Max pressure while upshifting to 1st
