Input not working with newest code
Halldorsson
Post by Halldorsson »
When using the latest code (5.104) for megashift input2 always stays low no matter what, I use the three inputs 1,2,3 for digital shift lever.
The circuit is working properly it gives 5V to processor and 0V when grounded.
When I switch to older code (4.146) everything works as it should.
Anybody has an idea for this?
Stefan
Re: Input not working with newest code
Stefan,
I will have a look on my bench. Could you post a datalog and your MSQ settings file of the problem in the meantime? It is possible that this could be a configuration issue, and a datalog always help eliminate possibilities more quickly.
Stefan,
Input 2 isn't working on my bench either (though the input 2 voltage swings from 0 to 5V on the gauge appropriately). Thanks for spotting this and bringing it up. I will fix it and post new code here as soon as I have a fix (it's likely a typo somewhere in the code, but that doesn't necessarily mean it will be easy to find...).
Stefan,
This 5.105ti test code and INI should work better for you:
Monitor_5105ti.abs.s19
(84.51 KiB) Downloaded 5860 times
GPIO_MShift_5105.ini
(297.42 KiB) Downloaded 5724 times
Input 2 now works as it should in limited testing on my bench.
The problem was in the way the code distinguishes between the GPIO hardware and the MicroTCU hardware.
The logic was obviously wrong, but I am not quite sure why it was written that way originally. So I need to figure that out at some point.
Let us know if this doesn't work for you.
Halldorsson
Lance
I just tested the new code and everything seems to be working so far.
Thank you for quick response, now I can go on with my project.
Stefan
Stefan,
Thanks for letting us know. If there's anything else that doesn't seem right, please post about it and we will get it sorted.
slyrye
Post by slyrye »
Input 4 is not working as well on the latest code :(
slyrye
Post by slyrye »
There seems to be a problem with Input 4 in TunerStudio there are no selection on the "Predefined Indicators" and Input 4 is non responsive on latest code 5.202, any insights on this? thanks very much
slyrye
Post by slyrye »
lance are you there brother? :(
looks dead... nothing from anyone, Lance or B&G .....
