4L80E code
1991blazer
Re: 4L80E code
Post by 1991blazer »
I uploaded this code and in park "current gear" shows 0 but "manual gear" shows -99 and is stuck there no matter what gear you put it into. Everything else looks fine.
Aaron
Re: 4L80E code
Aaron,
-99 for the 'manual gear' value means the code is not finding a manual gear lever position input pattern that matches any of those specified in the user inputs. I would need an MSQ and a datalog to be able to say much more.
Re: 4L80E code
I flashed the new code in the TCU, but did not test the car yet as it is raining.
but I did not get any problem with current gear or manual gear: everything is normal.( I only got an error message about a parameter Metric that does not have the right value and should be set manually)
I will let you know about the results from going in neutral later.
Re: 4L80E code
I just tested the new code, I did not see any difference:
going in neutral while driving, and then again in D, the transmission stayed in first gear, even when I tried shifting with the up and down switch, it did not go in manual mode.
Here is the datalog (too big to upload on the forum):
http://g.scheidt.free.fr/4l80/2014-05-04_09.47.05.msl
Re: 4L80E code
Guillaume,
Okay, I will dig a bit deeper!
Re: 4L80E code
Something else I just saw:
at approx 560 sec, while the car was in first gear, current geaar =4, i pressed the up and down buttons several time to see if I could go in manual mode, but it did not, and I don't see it on the datalog either.
(fields DWN and UP.) they were working earlier, at 225 sec.
Re: 4L80E code
gui67,
Another user was reporting issues getting into manual mode as well, and I will have a look at that too.
Re: 4L80E code
Guillaume,
I am still looking into this, and have some ideas. However, I also noticed that some info that might help has not been included in the INI/datalog. So I have edited the INI to include these things. The upgraded 4.140 INI is here: http://www.msgpio.com/manuals/mshift/fi ... t_4140.ini This should be used for future datalog whenever possible.
These changes will be included in all future INIs as well, of course.
Re: 4L80E code
Guys,
I found a few potential trouble spots in the code. These are fixed in the attached code. This code might fix your issues, but it might not; however if it doesn't fix things it will help narrow the problem down.
Monitor_4140c.abs.s19
Use INI from link immediately above.
(72.7 KiB) Downloaded 1125 times
BTW, to shift manually while in auto mode, you need to press the shift buttons twice. The first press activates manual mode, the second press (and any subsequent presses once in manual mode) does the actual shifting. I'm sure you all know that, but I thought I ought to be very clear for anyone who stumbles on this thread later.
Re: 4L80E code
i am having the same problem(always have actually) with popping into neutral then back into drive resulting in a first gear shift, i have to come to a stop or near stop shift to n then back into drive to get it to shift normal. i just got my car back on the road from last august or so and am currently running 4.127. im a bit behind on code revisions, is there a version i should try or go straight to 4.140. im running a ford 4r70w voltage based gear input.
