use of processor pin PE0 for table switching
Re: use of processor pin PE0 for table switching
OK, tried it, datalog attached. The log starts with the sport mode button engaged and it appears to 'float' between Table 2 and Default Table (I noticed the the 'decel' is doing the same). After about 15 seconds I disengage the sport button mode and it locks onto Default Table OK, engage sport mode button again and it starts floating again..
Martin
2015-02-22_17.55.16.msl
(101.27 KiB) Downloaded 785 times
Thanks for that, I will have a look and post back here when I have it sorted.
Martin,
The attached code appears to work correctly (finally!) for table switching with either PE0 or PE1 on my bench. Hopefully it works for you too.
Monitor_5099s.abs.s19
Uses previous INI
(82.57 KiB) Downloaded 805 times
Thanks Lance, just tested it and yes it works perfectly!
1st March this car becomes fully road legal, very exciting! that gives me 2 months to get it ready to drive 1000 miles across Europe :D
Cool, thanks for spotting the issue and testing the solutions. A road trip across Europe sounds like a lot of fun! Lance.
