The MegaSquirt Project has experienced explosive growth other the years, with hundreds of new MS installations occurring every week - a phenomenal success! MegaSquirt has been successfully used in all aspects of Internal Combustion engine applications including R&D, Industry, Race, and Research. The MS project has transformed itself from a simple R&D project into a full-featured mature engine control system. To reflect this the support structure has also changed to meet the needs of MegaSquirt Users.
Moving forward, the R&D forums for MegaSquirt project are in a read-only mode - no new forum posts are accepted.
However the forums will remain available for view, they still contain a wealth of information on how MegaSquirt works, how it is installed and used. Feel free to search the forums for information, facts, and overview.While the R&D forum traffic has slowed in recent years, this is not at all a reflection of Megasquirt users, which continue to grow year after year. What has changed is that the method of MegaSquirt support today has rapidly moved to Facebook, this is where the vast majority of interaction is happening now. For those not on Facebook the msextra forums is another place for product support. Finally, for product selection assistance, all of the MegaSquirt vendors are there to help you select a system, along with all of the required pieces to make it complete.
As above, will the megashift code work on the microsquirt module, I have one for a long term project but have also got a stronger trans for my range rover, a ZF4HP24e as opposed to the HP22, I can put together a hydraulic one but like the idea of the electronic controller as the engine is already running on MSIIe
I have found a bit more info on the trans, there are 2 solenoids for gear selection and a third for the TC lock up. The line pressure has the following specs
Type 2/2-way relief jet with falling characteristic line; the control edge
is closed when the valve is without power supply.
- Coil resistance R 5.5W +/- 6% @20°C
- I_max 700mA mean value
- I_min 150mA mean value
- Chopper frequency 1000Hz +/- 50Hz @ +25°C
- Control Unit
- Interface characteristic current regulated, chopped output stage, pulse width modulated.
- Current range 145mA <= I_min <=175mA @ +25°C
- Currrent range 680mA <=I_max <=720mA @ +25°C
- Reference point Pin 6 (power ground
- Recommended wire size: 1.0mm2
