1 is PCS has a universal stand-alone but it doesn't fine tune the trans enough.
2 is this is considered the strongest trans for a diesel pickup in stock form.
3 is I want this in my truck.
From what I read, this is a 6 spd trans that only uses 5 in a given day. It has a hot and cold operation, which according the the ATSG manual, that just changes 4th/5th gears. 4th is a 1.10:1 and 5th is 1:1.
I do have a bit of a problem though. The amount of solenoids...
There are 13 total, 8 of which are essential.
The solenoid data and what solenoids are needed for which gear and TCC solenoid operation:
http://www.superflow.com/Transmission_T ... 5r110w.pdf
The ATSG manual:
http://atsg.com/dyndata/articles/pdf/Fo ... qshift.pdf
Can I do this? If I can, I will make a lot of people happy.
Thanks!
