Speedo out to drive DC motor
- 80%.png (5.23 KiB) Viewed 16745 times
- 70%.png (5.4 KiB) Viewed 16745 times
- 60%.png (5.62 KiB) Viewed 16745 times
- 97%.png (4.85 KiB) Viewed 16745 times
- 90%.png (4.68 KiB) Viewed 16745 times
Measured at the Trans Stim.
- PC93%.png (8.76 KiB) Viewed 16745 times
- PC61%.png (8.86 KiB) Viewed 16745 times
Are these shot while shifting, or in a 'steady state'?
These scope shots are all on spare port SP1?
I see a problem on the bench. The PWM works as planned - except that the off period isn't fully off (it fluctuates between off and on). That is leading to the 'jumpiness' you are seeing. I will dig into the code shortly to sort this out. Thanks for your patience on this - it's how the code gets fixed.
All exept the last post that are on PC out put.Lance wrote:tobmag,
