Audi 094 4 Speed - Solenoid Output
KamikazeTuner
Output 1 - VB1 - Solenoid 1
Output 2 - VB2 - Solenoid 2
Output 3 - VB3 - Solenoid 3
Output 4 - VB4 - Solenoid 4
Spare Output 1 - PWM 2 - Solenoid 5 (use as shift Solenoid)
Spare Output 2 - PWM 4 - Solenoid 7 (use as shift Solenoid)
Output 6 - PWM 3 - Solenoid 6 (use PWM)
Seems like it would make more sense. The hardware is already setup for this, I just don't know where to make the appropriate changes in TunerStudio MS. Will this require a change in the embeded code of the GPIO?
I am running MShift software version - GPIO_MShift_2202
Thanks in advance for the help.
Re: Audi 094 4 Speed - Solenoid Output
I am not sure I understand what you are asking. However, this may help: You set up the spare ports under 'Spare Ports' on the main menu. Start with the 'Spare Port Function': http://www.msgpio.com/manuals/mshift/V22tune.html#sf When you set the spare ports to shift outputs, then they will be visible in the 'Shift Output Patterns' menu (next).
For all of the the shift solenoids (incl. spare ports if configured as shift outputs), you set these up under 'Shift Output Patterns' on the main menu: http://www.msgpio.com/manuals/mshift/V22tune.html#h
Clutch patterns are set under 'Shift Output Patterns/Clutch Pattern' ( http://www.msgpio.com/manuals/mshift/V22tune.html#hh ), but these are only visible after the spare output has been set to a clutch output above.
The pressure control solenoid is already set up as an output on - PT2 - PWM3 - Amp 27, see 'Tables/Pressure Control Table': http://www.msgpio.com/manuals/mshift/V22tune.html#ap
KamikazeTuner
As always, Thank you for the quick response. The problem is that when I set Spare 1 and 2 to Clutch outputs, I lose a shift solenoid (3 shifts and 2 clutch) and when I set them all as Shift solenoids, I am still short one shift solenoid. Thanks to the TransStim, I was able to figure out I am not getting an output signal from VB2/Spare Output 2 and no response from my TCC output. All other outputs look to be working fine.
To clear up my original question. I would like to configure VB1, VB2, VB3 and VB4 as Outputs 1, 2, 3 ,4 and leave my Spare Outputs 1 and 2 to control my Clutch Solenoids. It would make more logic for my application. If not, I will try to work around it.
P.S. My Pressure Control is working great, so that solenoid does not need any further mods.
- VB2 issue.JPG (43.73 KiB) Viewed 25906 times
KamikazeTuner
I just noticed a HUGE mistake in my part. When building the board, in particular jumping the 25x2 headers. I accidentally jumped AD1 to VB2 instead of the correct method of AD1 to GPI2. That explains why I an having all these issues with Inputs and Outputs. I will correct it and report back.
KamikazeTuner
KamikazeTuner
KamikazeTuner
Correction and advice-
Also, it is recommended to cycle the power (off-on) when making changes. I found it much more reliable to make changes with the Board OFF, then cycling after that to be sure that Tuner Studio and the board are synced up. It's takes a little bit more time, but I have not had any more issues after doing it this way.
1. with the board off. Make changes in Tuner Studio.
2. Turn the board on and allow Tuner Studio and the board to sync. (will ask for your approval to the changes)
3. Turn the board off (be sure its completely off...about 5-10 seconds) the on one more time to make sure everything is synced. (not required, but I have not had a problem since doing it this way)
Also, take good notes of all the changes you make, if things are not responding the way you expect them to, you may have to reload the .s19 file. It cleared up lots of small problems I was having. Now my board is working GREAT!!
I just need KamikazeTuner to log back in, especially if he has the shift patterns in a manual as I'm struggling to find that info..
