4.103 INI correction
I was away for a week so i'm a bit late with testing, v4.103 PRN led pattern works fine, the separate pattern for P is very nice, but for the N led pattern the 3rd led alternating you can select off,on,2,3 !!!
Jacco
Whoops! That was a bit pattern typo in the INI (it had [6:7] instead of [6:6]). It is fixed in this INI:
http://www.msgpio.com/manuals/mshift/fi ... t_4103.ini
You have uploaded the old ini with the typo still in it, but I corrected the typo myself and it is working fine now.
Jacco
Actually, I think you were looking at a cached copy from your PC or your ISP. The corrected INI is dated June 27, 2012 in the first few lines, and works fine for me from the link above. If others run into that issue, they should use the ctrl-F5 keystroke combination in the browser to clear their cache.
