Logging transmission parameter with MS3 SDcard
gear, trans temperature, lever position... on the SD from MS3? I quickly looked for that last Saturday but I did not find it.
Guillaume
Re: Logging transmission parameter with MS3 SDcard
It's certainly possible, since the CAN infrastructure allows this. The MShift implementation of the CAN protocol is exactly the same as the 2.905 (and higher) MS-II code from B&G. However, I have no idea about whether ms3 supports this without changes, or whether code changes to ms3 are required. You would have to ask the developers of ms3 about this (on msextra.com).
