AA80E 8-speed
It's still running in 3rd gear.
Paddle upshift still doesn't work.
- 2016-10-21_15.05.11.msl
- (2.21 MiB) Downloaded 435 times
- 2016-10-21_14.59.42.msl
- (1.57 MiB) Downloaded 413 times
- 2016-10-21_15.20.34.msq
- (2.9 KiB) Downloaded 670 times
Did the new upload drop out the variables when it was loaded? I'm not the most proficient with this and forget how it works. Does this mean I have to go back and re-enter the Mshift variables? (I'm assuming, yes, that was what you told me to do. I'm just unclear on exactly what these Mshift variables are that I'm supposed to re-enter, and where they are located.)
I'm guessing I should find these variables by opening TS with an earlier msq and search for anything that is different, then copy them to the new tune?
BTW, I thought of a way to test the function of the shift trigger solenoid. I should be able to cut the wire that comes out of the controller and wire in a hand held push button switch, then press the button when I shift into drive. If that starts the car in 1st gear instead of 3rd I should then be able to successively use button presses to upshift through the gear range and back down again, since presumably the controller will be commanding shifts in automatic fashion. What do you think? As soon as I get these Mshift variables sorted I should be able to try that.
Thanks for the assistance,
Looks like I will have to go through everything item by item, line by line and make sure it matches the msq from before the s19 file was revised if I understand correctly.
So what do you think of my workaround with the pushbutton switch? Sound feasible to you? It's the only alternative I can think of for getting the transmission valve body out of "Limp" mode aside from switching the AD4 and PT6 ports and setting up a trigger pulse on PT6.
We talked about this way back before I built the controller, and I thought you said you could do that. Is it that difficult?
I realize this means there has to be a code variant just for the AA80E specifically. But aren't there specific variants for other transmissions too? I also realize that 5 years ago you probably were a lot more interested in pursuing this that you are now. I may be the only pioneer right now, but my work is freely available to anyone else who follows along, and second time around the build just isn't that much different from the norm. I've been careful to blaze a good trail and leave a record that should be easy to follow.
If it wasn't in essence closed source I might have other alternatives, my son does programming and could look at it. But with an entry barrier of $1000 or more just to get the software to look at the code that's a mite stiff for a single application. Even as a student he can't afford the software. He says the proprietary compiler is the problem, otherwise he could help. Wasn't all this Mega stuff supposed to be open source?
No, there are no code variants, it's all one code with options.
If you want to write your own code, your best bet is to start with this code: http://www.msgpio.com/manuals/iocode/Te ... t_1101.zip
This code is small enough that you can use the free special edition of codewarrior from this page: http://cache.freescale.com/lgfiles/devs ... =Downloads (you have to register)
You could also start with the 1.100 MShift code here: http://www.msgpio.com/manuals/mshift/GP ... oj1100.zip as this is small enough to compile 'as is' on the special edition of CW but already has numerous transmission functions coded.
You will also want the MC9S12C Family Reference Manual, it contains much of the information you will need when programming the GPIO's processor (things like register definitions, etc.). You can get the reference manual here: http://www.msgpio.com/manuals/iocode/MC9S12C128V1.zip
If you want to work with the latest code, here is 5.201: However, you will have to strip a fair bit of the code out (there ought to be lots of code in there that you don't need for your transmission control) to be able to compile this with the special edition of CW and its 32K limit, and making deletions from the code is not a trivial task.
