duplicate instructs in the GPIO build?
tmoble
Post by tmoble »
very early in the build process there's a MUST line instructing to run a couple jumper wires on the 25x2 header, then cut the pins off the bottom of the header so they don't interfere.
Very late in the process it had me install two jumper wires on the 25x2 headers. It's:
Input 2 (switchB) AD1 GPI2 (jumper at 25x2 header) 6
and
Spare Output1 (SP1) PT7 VB1 (jumper at 25x2 header) 11
Since it instructed me to cut the pins it seems this step is meaningless. Should I pull it out of the case and remove those two wires?
Re: duplicate instructs in the GPIO build?
Which set of instructions are your referring to (i.e. do you have a link)?
panel
Post by panel »
Hey Lance can you PM me or shoot me an email at minstone@shaw.ca , thx!
Subaru conversion EJ20 Turbo VW bus http://www.vvwc.ca/modules.php?name=For ... pic&t=9091
tmoble
Post by tmoble »
here:
http://www.msgpio.com/manuals/mshift/assembly.html step 11
and
did somebody clean it up already? I don't see the lines I pasted in the instructions.
Is there more than one set of build instructions?
tmoble, we can't find any record of that page being changed in recently (in the last several months at least), so perhaps you had a cached version that you were viewing. There are other versions of the build instructions for things like the 4L80e transmission, etc..
