ford 6R80
razzys wagon
ford 6R80
Post by razzys wagon » Sat Nov 28, 2015 8:58 am
has anyone attempted one of the new ford 6R80s yet? I may be putting one in my fox mustang(ms3x controlled) and as soon as I find a bell or adapter plate (or fabricate said item) since my Lentech strip termy has bitten the dust again.....my car is heavy and the 6R80 has been proven several times in the new coyote cars at my weight and power level......
Thor_patrol
Re: ford 6R80
Post by Thor_patrol » Wed Dec 09, 2015 12:35 am
Hi there,
I'm about to start on a 6r80 transmission very shortly. I've already got the Trans installed and adapted to my engine, fitted an exedy frictions kit and am using a tci bolt together torque converter. I'm leaving the transmission until last as i think it will be a bit of a challenge. I've done a fair amount of research on the trans and it is certainly possible from what i can see. The 6r80 I've used is from a Ford territory diesel because they came with an external control unit instead of the internal mechatronic unit which i believe is in most 6r80 transmissions.
razzys wagon
Re: ford 6R80
Post by razzys wagon » Thu May 12, 2016 5:34 pm
Hi Dave, thanks for posting. I had all but given up!!!! Sorry it's been so long as I didn't get a notification....have you got a component list for the 6r80 layout by chance?
Mark
Thor_patrol
Re: ford 6R80
Post by Thor_patrol » Wed Jun 08, 2016 1:38 pm
Hi Mark,
I'll have to look over what I did exactly, but I'll get it up as soon as I have time. I originally built mine for a 4l80 and only had to change minimal things to suit the 6r80. I'll give you all the pwm settings and what outputs etc. That I used.
Cheers,
razzys wagon
Re: ford 6R80
Post by razzys wagon » Wed Jun 08, 2016 2:17 pm
Good deal!! I may see if I can get my hands on a control unit like you have, I have a friend in Melbourne, AU, Paul Cibotto, CVE Performance, I may see if he can locate one for me....but yes, please do post up your changes, thanks for you help in advance!!
Thor_patrol
Re: ford 6R80
Post by Thor_patrol » Wed Jun 08, 2016 6:49 pm
Do all the 6r80 have the external tcu in the states? It would certainly be possible to change it out, the whole leadframe thing that has the solenoids, temp sensor and speed sensors looks identical, it just hasn't got the inbuilt computer in it and the output plug has more pins. I had the original ford lead that attached to the Trans and I ordered a molex plug and pins which was the same as the tcu unit that would have been on the Trans. I have a spare lead and can send you a picture and the part numbers of the plug I ordered. I got it from mouser from their website.
I'm also in Melbourne so if you need anything to give to your mate it shouldn't be a problem.
Cheers,
razzys wagon
Re: ford 6R80
Post by razzys wagon » Wed Jun 08, 2016 6:54 pm
Nice, yes, I think all are internal here. You think they would have the plug for the internal style tcu? In your research, were the control properties the same? Like pwm or were the internal one run a different way? I'll be hitting the dealership tomorrow for information.
razzys wagon
Re: ford 6R80
Post by razzys wagon » Fri Jun 10, 2016 7:50 am
wrong, they are not, nothing but solenoids and the usual inside on the VB.
Thor_patrol
Re: ford 6R80
Post by Thor_patrol » Thu Jun 30, 2016 4:31 am
Haven't forgotten about this, will get all the info up soon
razzys wagon
Re: ford 6R80
Post by razzys wagon » Thu Jun 30, 2016 6:44 am
im on the same schedule....lol
