Manual Incorrect?
Posted: Sun Aug 02, 2015 3:24 am
I believe the manual may be incorrect on the following point:
This page http://www.msgpio.com/manuals/mshift/test.html states"
I believe (from reading documentation on the 4L60e) the bit about NOT starting the vehicle is wrong? My understanding of those switches are that they only change condition if there is hydraulic pressure in the transmission AND with the corresponding gear selected WITH ENGINE RUNNING. This is contrary to external gear lever position switches that provide conditions purely on the basis of the gear lever position.Check the manual gear shift lever function. Select 'Manual Gear' as one of the gauges on your front page. Without starting the vehicle, shift the manual gear selector lever through each of its gears. Verify that the Manual Gear gauge shows the actual position of the gear selector lever at all times.
