CAN confusion
Philip Lochner
CAN confusion
Post by Philip Lochner »
I'm at the point where I'm trying to communicate with MShift via my MS-2's CAN bus. Ie serial comms from PC to MS2 and then CAN to Mshift.
I get to this point and then I'm not sure what's going on:
Best regards
Philip
'80 Jaguar XJS 5.3L V12 = MS-2
'74 Jensen Interceptor Mk3 440 V8 = MS-2 + GPIO (GM 4L60e)
Re: CAN confusion
Philip,
There are two potential issues here:
1) Make sure you have the correct INI. It appears that you are showing both 5.101 and 5.102. Make sure the INI matches the code you have (5.102 is best, get the code/INI here: http://www.msgpio.com/manuals/mshift/V5code.html)
2) TunerStudio often mixes up the reported firmware version when connecting for the first time using the CANbus. If you get an obvious firmware mismatch that says your current reported firmware is in fact the engine ECU's firmware, you should "connect anyways". The error will only happen once (or at least once until you change firmware). TS has done this for years to me, but it has never caused a problem on my setup (other than the misleading mismatch message).
Philip Lochner
Re: CAN confusion
Lance wrote: Make sure the INI matches the code you have (5.102 is best, get the code/INI here: http://www.msgpio.com/manuals/mshift/V5code.html)
Thanks Lance, but did you see this? viewtopic.php?f=4&t=1012&p=5478&sid=bf5 ... f507#p5478
Best regards
Philip
