VRx Interrupt calls
Posted: Wed May 08, 2013 11:12 am
by SebastianS
Hello again,
I'm struggling to get the VR Sensor inputs to work. I've managed to successfully read VR1 on PT0 by modifying the template's "VSS_timer" Interrupt Service Routine.
When trying to read the other sensors though, it seems that another ISR is being called that jams my controller in an infinite loop everytime I create an interrupt through the sensors.
My question is: Where can I find the mapping of what interrupt flag of the timer module (set in TFLG1) calls what ISR?
Regards,
Sebastian
Re: VRx Interrupt calls
Posted: Wed May 08, 2013 2:28 pm
Sebastian,
The mapping of interrupt events to the code that should be run when they occur (called 'interrupt service routines' or 'event handlers') is set in a section of the code called the 'interrupt vector table' (located in a specific section of the memory). It looks like this:
typedef void (* NEAR tIsrFunc)(void);
const tIsrFunc _vect[] VECT_ATTR = {      // Interrupt table placed at 0xFF80
        UnimplementedISR,                 // vector 63, 0xFF80
        UnimplementedISR,                 // vector 62, 0xFF82
        UnimplementedISR,                 // vector 61, 0xFF84
        UnimplementedISR,                 // vector 60, 0xFF86
        UnimplementedISR,                 // vector 59, 0xFF88
        UnimplementedISR,                 // vector 58, 0xFF8A
        UnimplementedISR,                 // vector 57, 0xFF8C - PWM emergency shut-down
        UnimplementedISR,                 // vector 56, 0xFF8E
        UnimplementedISR,                 // vector 55, 0xFF90
        UnimplementedISR,                 // vector 54, 0xFF92
        UnimplementedISR,                 // vector 53, 0xFF94
        UnimplementedISR,                 // vector 52, 0xFF96
        UnimplementedISR,                 // vector 51, 0xFF98
        UnimplementedISR,                 // vector 50, 0xFF9A
        UnimplementedISR,                 // vector 49, 0xFF9C
        UnimplementedISR,                 // vector 48, 0xFF9E
        UnimplementedISR,                 // vector 47, 0xFFA0
        UnimplementedISR,                 // vector 46, 0xFFA2
        UnimplementedISR,                 // vector 45, 0xFFA4
        UnimplementedISR,                 // vector 44, 0xFFA6
        UnimplementedISR,                 // vector 43, 0xFFA8
        UnimplementedISR,                 // vector 42, 0xFFAA
        UnimplementedISR,                 // vector 41, 0xFFAC
        UnimplementedISR,                 // vector 40, 0xFFAE
        CanTxIsr,                                 // vector 39, 0xFFB0
        CanRxIsr,                         // vector 38, 0xFFB2
        CanRxIsr,                         // vector 37, 0xFFB4
        UnimplementedISR,                 // vector 36, 0xFFB6
        UnimplementedISR,                 // vector 35, 0xFFB8
        UnimplementedISR,                 // vector 34, 0xFFBA
        UnimplementedISR,                 // vector 33, 0xFFBC
        UnimplementedISR,                 // vector 32, 0xFFBE
        UnimplementedISR,                 // vector 31, 0xFFC0
        UnimplementedISR,                 // vector 30, 0xFFC2
        UnimplementedISR,                 // vector 29, 0xFFC4
        UnimplementedISR,                 // vector 28, 0xFFC6
        UnimplementedISR,                 // vector 27, 0xFFC8
        UnimplementedISR,                 // vector 26, 0xFFCA
        UnimplementedISR,                 // vector 25, 0xFFCC
        UnimplementedISR,                 // vector 24, 0xFFCE
        UnimplementedISR,                 // vector 23, 0xFFD0
        UnimplementedISR,                 // vector 22, 0xFFD2
        UnimplementedISR,                 // vector 21, 0xFFD4
	ISR_SCI_Comm,                     // vector 20, 0xFFD6
        UnimplementedISR,                 // vector 19, 0xFFD8
        UnimplementedISR,                 // vector 18, 0xFFDA
        UnimplementedISR,                 // vector 17, 0xFFBC
        Timer_Overflow_ISR,               // vector 16, 0xFFDE
        UnimplementedISR,                 // vector 15, 0xFFE0
        UnimplementedISR,                 // vector 14, 0xFFE2
        ISS_timer,                        // vector 13, 0xFFE4
        UnimplementedISR,                 // vector 12, 0xFFE6
        UnimplementedISR,                 // vector 11, 0xFFE8
        UnimplementedISR,                 // vector 10, 0xFFEA
        UnimplementedISR,                 // vector 09, 0xFFEC
        VSS_timer,                        // vector 08, 0xFFEE
        Timer_Clock_ISR,                  // vector 07, 0xFFF0 - RTI
        UnimplementedISR,                 // vector 06, 0xFFF2 - IRQ (PE1)
        UnimplementedISR,                 // vector 05, 0xFFF4 - XIRQ (PE0)
        UnimplementedISR,                 // vector 04, 0xFFF6 - SWI
        UnimplementedISR,                 // vector 03, 0xFFF8
        UnimplementedISR,                 // vector 02, 0xFFFA - COP failure reset
        UnimplementedISR,                 // vector 01, 0xFFFC - Clock monitor failure reset
        _Startup                          // Reset vector, 0xFFFE
For the details, see 'Chapter 5 Interrupt (INTV1) Block Description' of the reference manual here: http://www.msgpio.com/manuals/iocode/MC9S12C128V1.zip You might also want to check this chapter for the timer info: 'Chapter 15 Timer Module (TIM16B8CV1) Block Description'. Other, easier to read, sources of more general info are: http://www.ee.nmt.edu/~erives/308_11/Lecture14.pdf and http://services.eng.uts.edu.au/pmcl/emb ... ture05.pdf
Posted: Thu May 09, 2013 2:50 am
by SebastianS
thank you, that was extremely helpful - especially the first paper with general info as it contains the table mapping (page 16) that I couldn't find in the manual or the code itself.
That table was exactly what I was looking for :)
Sebastian
